GF columns cleaning in GMP
Posted: Mon Sep 29, 2014 1:53 pm
I have a 2.5L column with Sepharose 4 FF that I need to sanitize with 1M NaOH. After sanitization (with a contact time of 60 min), samples of the final rinsing water are taken to TOC and Bioburden analysis. The sanitization and sampling are performed in a Clean Room class C and to avoid external contaminations I also sanitize the external of the inlet and outlet tubing.
The question is that even with a low TOC, the acceptance criteria for bioburden (1 cfu per 10 mL) of the column sample is always out of specification.
Does anyone know what I might be doing wrong? Any sugestion?
Any comment would be helpful.
Thank you in advance.
