Concentration of analytical standard
Posted: Mon Sep 29, 2014 9:21 am
Hi everyone !
A technical question about a situation I was hoping you could help understand. I am not a HPLC specialist, so it could be quite easy, I don't know.
I use to work with analytical standards from Sigma Aldrich for HPLC concentration measures. This works fine for me, but looking at the analysis certificate provided with the standard, I couldn't understand where they got the precise concentration value for this sample.
I don't know if they use the same technique for all their standards, but with mine they use the peak area % value from a HPLC test with a UV detector to establish the concentration of the substance. This seems a bit approximatical to me, as depending on the wavelenght, the peaks of some impurities could be underestimated, or even invisible because of the solvent choice.
Could anyone confirm that this method is sufficiently precise (to justify the price of such tiny samples...) ? And why it is ?
Thanks a lot guys !
Thanks a lot guys !
