HP5890 inlet seal question (0.8 mm vs 1.2 mm)
Posted: Thu Sep 25, 2014 9:19 pm
I've noticed that there are 0.8 mm inlet seals and also 1.2 mm inlet seals (the gold disc with a hole in it under the injection port, in the oven) available for the HP5890 GC.
Why would one chose the 1.2 mm seal over the 0.8 mm seal? I'm pretty sure I've got the 0.8 mm seal but I don't have a way to measure it at the moment.
Thanks!
Thanks!
