GPC/SEC-MS
Posted: Thu Sep 18, 2014 5:00 pm
by jabolko
Hello to everyone,
i am writing to ask if someone can tell me which salts can be used in GPC-MS technique, for improving separation and ionization of compounds?
Thank you in advance for answers.
Best Regards,
Jabolko
Re: GPC/SEC-MS
Posted: Fri Sep 19, 2014 2:10 pm
by JMB
Since GPC/SEC separations are based solely (or should be) on molecular size (correlates to MW, roughly) why do you think that addition of a salt would help the separation ??
Re: GPC/SEC-MS
Posted: Fri Sep 19, 2014 10:33 pm
by Karen01
It is a standard way of preventing mixed mode chromatography in GPC/SEC so that retention is due only to size exclusion.
- Karen
Re: GPC/SEC-MS
Posted: Sat Sep 20, 2014 9:22 am
by jabolko
use of salts and GPC samples prevent interaction with column..as Karen said retention is then only due to size exclusion ...
I want to connect GPC / SEC with MS detector..so I would like to know if someone doing this to tell me which salts you are using here ?? Which one kind for polar and nonpolar components for ..
Jabolko
Re: GPC/SEC-MS
Posted: Sat Sep 20, 2014 1:08 pm
by JMB
For ESI-MS, you generally need a volatile salt, e.g. ammonium acetate, that will not deposit in the ionization source.
Some MS instruments with a particular source geometry (orthogonal) allow the use of traditional, non-volatile salts (e.g. phosphates or NaCl); but even they eventually succumb to the presence of solid deposits and cease to function properly until the source is cleaned.
