6890-Tekmar 7000 Pulsed Split
Posted: Wed Sep 17, 2014 10:57 pm
Hi all I have started running my Tekmar 7000 today.
I am trying to use a pulsed split injection to minimize the split necessary. I set it up for a 3:1 split at 30 psi for 1 minute. That translates to 3 ml/min column flow 12ml/min total down the transferline. The trouble is it seems like the Tekmar 7000 doesn't tell the GC to go to prep run. It takes a minute for the EPC to generate the appropriate split and pressure. However, It goes right from standby (1 ml/min column gas saver) to inject/start. I ran a few injections by manually hitting prep run and it looks good but the 7000 gripes about constant heat time violations.
I have injection source set to manual inject. What is the difference between manual inject and external device in Chemstation MSD? Finally how can I program the pulsed split so the GC EPC has time to generate the appropriate values before inject.
