Baseline Subtraction using Varian Star Workstation
Posted: Sun Sep 07, 2014 9:53 pm
by entropiclabs
Hi everyone. I've been working at 225nm wavelength using a methanol gradient, and quite obviously I've been getting serious baseline drift. I want to correct for it, but I'm having a bit of difficulty processing the data files, so...
How do you subtract a baseline run on Star workstation? I ran a blank and labeled it as a "baseline" run on the samplelist. On the method, in the integration parameters, I selected "subtract baseline". So my next question is how to view the results? In the interactive graphics, I open the method, then I open the "baseline" file and my analysis file. When I click "view results" for the analysis run I don't see the subtracted baseline? Do I have to re-integrate? Any help would be appreciated, thank you!
Also, any help on how to use the "Preview Baseline Subtraction" during an actual run would also be really helpful, thanks.
