Export Empower Database data
Posted: Fri Aug 29, 2014 7:28 pm
Hi to everyone,
I am working to a project where I need to extract from an Empower project the total injection number. The ideal would be to create an exporting method which allows me to select various sample sets and export all the injection done in an ASCII file. Finally I wanna open the ASCII file containing all data (injection ID, Sample Name and Date Acquired) in Excel and then build few pivot tables and graphs in order to analise the lab performances.
Can you explain me how to set up Empower 2 Export Field in order to achieve a table with the all injections performed?
Thanks a lot
Thanks a lot
