How does ApexTrack calculate the inflection tangents?
Posted: Fri Aug 29, 2014 2:28 pm
by badger
I'm trying to determine system suitability in Empower 2 without actually having the system suitability feature installed. So my idea is to measure peak width at the baseline by using the 2nd derivative plot to determine inflection points and then when I get the line use the zeroed baseline spectrum to find the zeroes of the tangent lines. Therefore my question is how does ApexTrack numerically determine the inflection tangents. The way I would do it is to average the slopes between the nearest bunching points before and after the inflection points. Thanks.
Re: How does ApexTrack calculate the inflection tangents?
Posted: Fri Aug 29, 2014 3:30 pm
by badger
Apologies, this should probably be in the computing section. A related question, how do I even find the tangent points? Current method is to look at the inflection width and see what pair of time points fits that into the curve.
Posted: Fri Aug 29, 2014 9:10 pm
by Hollow
there should be some documentation available in the empower help or PDA manual or on the Waters homepage.
A nice book dealing with the integration of chromatograms is:
Quantification in LC and GC: A guide to good chromatographic data
Hans-Joachim Kuss, Stavros Kromidas
Wiley-VCH, 2009
ISBN: 978-3-527-32301-2
