error message on GC
Posted: Wed Aug 27, 2014 4:08 pm
Hello, I have a Shimadzu GC 2010 and am having the following error message when I try to change the column temperature: car2 calc. ratio out of range. I did some searching and found that "the carrier gas total flow rate calculated from the split ratio program you have input is outside the set range." I am guessing there is a setting somewhere in the GC where the max split ratio is set too low--where could this be?
Also, I am having detector issues. The computer and GC are communicating (ie I can change temps on the GC from the computer), but the line stays flat on the computer screen--it does not spike up when I turn on the detector. Any ideas?
Laura
Laura
