Chemstation batch report error: cannot load data file
Posted: Sun Aug 24, 2014 12:10 pm
by mauritmau
I use the batch report in the Chemstation Software quite frequently. Until now everything worked fine. In one run the data file is missing (I do not know why). The batch processing stops with an error message : "ERROR: Processing Run: Error during batch processing: Data file xxxx.D not loaded"
i do not care much about this missing data file. I would like to have all other runs exported. But the processing stops and nothing is exported.
Does anyone know a solution ? (Chemstation LC Rev B.04.03 (16) )
Re: Chemstation batch report error: cannot load data file
Posted: Tue Aug 26, 2014 1:25 pm
by lmh
you could try copying one of the existing files, giving the copy the name of the missing file, and see if Chemstation notices...
Posted: Tue Aug 26, 2014 6:25 pm
by dblux_
Then exclude missing file from batch processing.
