EMPOWER 2: Cannot save results after manual integration
Posted: Wed Aug 20, 2014 9:38 pm
by slantz999
Hi all -
I can no longer save results after performing manual integration. When I go to the File > Save submenu, the Result option is grayed out (as are all the other options). Does anyone know what can cause this?
I have the same problem when trying to Monitor or Setup Instrument Methods in the Run Samples window. When I select the Instrument Method from the dropdown menu in the box, the Monitor and Setup options are grayed out (only Edit can be selected).
Thanks for your help.
Re: EMPOWER 2: Cannot save results after manual integration
Posted: Thu Aug 21, 2014 8:01 am
by scottythree
Sounds like someone may have changed user permissions.
Posted: Thu Aug 21, 2014 8:07 am
by kubowicz.tomasz
Hello
Just ask Admin to check your account privileges.
Regards
Tomasz Kubowicz
Posted: Mon Aug 25, 2014 8:01 am
by a.wombat64
Hi kubowicz.tomasz
another possibility: Is there a "Read Only lock" or "Full Lock" on the project?
Best regards
