Empower- Want to print custom calculations in report
Posted: Wed Aug 20, 2014 6:35 pm
by tristanewalters
Hello all-
Does anyone know if it is possible/how to print the custom calculations used in an Empower report?
Thanks for the help.
Re: Empower- Want to print custom calculations in report
Posted: Thu Aug 21, 2014 9:14 am
by benW
You can print all the custom fields for the project, by selecting special information>project custom fields,
and this will list all your custom fields, their properties and formula (can also add a table of result custom fields).
It is not posible to filter the fields to just the fields present in the report, which is the problem.
But the information is there if it is a must, and realistically you are probably looking at between 15 and 30 custom fields in each project?
Posted: Thu Aug 21, 2014 2:31 pm
by tristanewalters
Thanks Ben.
I had looked over the reports for awhile and wasn't having any luck finding it!
Printing out the different custom fields shouldn't be a problem because we will have projects specific to our test methods.
Again, thank you for your help
