EZchrom Elite 3.3.1 Column Compensation
Posted: Tue Aug 19, 2014 7:00 pm
by bstratton
I can see where you select the detector minus column comp. However, I am having trouble finding where you actually perform the column compensation run.
Brad
Re: EZchrom Elite 3.3.1 Column Compensation
Posted: Tue Aug 19, 2014 7:22 pm
by kubowicz.tomasz
Hello
If you're using Agilent GC do as below:
You need to run it from GC keybord. After your ColComp is saved you need to run your method with "detector signal - column compensation"
Regards
Tomasz Kubowicz
Posted: Tue Aug 19, 2014 7:23 pm
by bstratton
Hello
Regards
Tomasz Kubowicz
Thanks for the response. I guess I should have noted this is a Agilent 6850 connected to a computer running EZchrom Elite 3.3.1. Is it possible to do the column compensation run in EZchrom Elite?
Brad
Posted: Tue Aug 19, 2014 7:29 pm
by kubowicz.tomasz
Hello
I'm not sure if you can run it in EZCh but check detector signal options...you should have dropdown menu with
-signal
-signal - column compensation
-column compensation
If not, use hand controler from GC 6850 (instant pilot) to run it
Regards
Tomasz Kubowicz
Posted: Tue Aug 19, 2014 8:41 pm
by bstratton
Hello
-signal
Regards
Tomasz Kubowicz
We installed the hand controller from another 6850 and ran the column comp using that. I already had seen where you select the detector signal options but have not been able to find anywhere where you can run a column comp run inside of EZChrome.
Thank,
Brad
Posted: Tue Aug 19, 2014 9:01 pm
by kubowicz.tomasz
Hello
If you ran column compensation from GC6850 hand controler and you stored it just go to EZChrom instrument control - detector and mark as below:(example is for FID but you can do it with other detectors as well)
Regards
Tomasz Kubowicz
