Chromatogram percentage. Mass, mol or carbon number?
Posted: Mon Aug 18, 2014 9:31 pm
Hello to everyone as this is my first post in the forum and i apologize beforehand if it is a silly question.
Assume that i have chromatogram like that
time (min)_______area (%)_______component
__3.2_____________53____________ethanol
__6.7_____________28____________butanol
I have hard time assessing this result, which one of the following is true?
a) the ethanol to butanol mass ratio in the sample is 53/28=1.893
b) the ethanol to butanol mol ratio in the sample is 53/28=1.893
c) the ethanol to butanol mol ratio in the sample is (53/2)/(28/4)=3.786
I assume c is right since i think FID detects the carbon molar flow with respect to time (i searched a little about FID's but could not find an answer or i found and did not understand). Therefore given area percentages must be divided by the carbon amounts of the each component respectively before comparing them between each other.
Any help would be much appreciated. Thanks in advance.
