Agilent MSD ChemStation Results Manipulation
Posted: Fri Aug 15, 2014 4:04 pm
by STC
Hello all,
I have the following:
GC HP 6890
MSD HP 5973
they are both being run by the Agilent Chemstation Software. For data analysis I am using the MSD Enhanced data analysis that came with the software.
I am able to run samples consistently, however I want to compare the results. Is there a way to overlay the results (graphs/peaks) so that I can compare the different trials visually?
Thanks in advance,
STC
Re: Agilent MSD ChemStation Results Manipulation
Posted: Fri Aug 15, 2014 4:50 pm
by kubowicz.tomasz
Hello
You need to open Data Analysis. Then:
Tools - Overlay Chromatograms
You can overlay TIC or SIM
Regards
Tomasz Kubowicz
Posted: Fri Aug 15, 2014 5:54 pm
by STC
Mr. Kubowicz!
Its you again! Thanks!
