Degrees of freedom (statistics)
Posted: Tue Aug 12, 2014 1:12 pm
Hi everybody
I am not sure if I understand my statistics textbooks correctly. Numerous equations refer to the degrees of freedom. What exactly is this?
Example: I run a calibration with 6 concentration levels. Each level is injected in duplicate. Is the number n I use to calculate the degrees of freedom 6 (because there are 6 concentration levels) or 12 (because I have measured 12 data points)?
Thanks for enlightenment,
Jörg
Jörg
