Channel A and B
Posted: Sun Aug 03, 2014 7:36 pm
by sga
Pump: Bin 1100.
Channel A : Water
Channel B : ACN
A:B :: 80%:20 %
How can we confirm that the composition of the final eluent stream IS indeed 80:20 and remains stable through out the entire run ?
Does any one know what kind of variability can exist or what kind of variability is considered as acceptable ?
Regards
Re: Channel A and B
Posted: Mon Aug 04, 2014 5:11 am
by Gerhard Kratz
You need to measure flow rates of each channel. No variability acceptable.
Use a graduated cylinder and a stop watch. 10 ml is enough.
Re: Channel A and B
Posted: Mon Aug 04, 2014 8:17 am
by kubowicz.tomasz
Hello
You can prepare marker (0.4% Acetone in Water) and run gradient test for all 4 channels. You can either use Agilent method (verification mode in Chemstation) or prepare your own and compare gradient profile for different composition.
If you use verification test from OQ/PV you can have full report with results.
Regards
Tomasz Kubowicz
Re: Channel A and B
Posted: Mon Aug 04, 2014 6:39 pm
by Consumer Products Guy
He has a binary pump, so only needs to do 2 channels.
Re: Channel A and B
Posted: Tue Aug 05, 2014 6:15 am
by kubowicz.tomasz
I assumed that pump has solvent selection valve
Re: Channel A and B
Posted: Tue Aug 12, 2014 2:10 pm
by Ibn_Sina
Hello
Regards
Tomasz Kubowicz
Tomasz is absolutely spot on with his reply, however the ability to run this test depends on the version of Chemstation. I believe versions below B.04.03 should have the OQ/PV tab in the navigation panel, anything B.04.03 and above will not have this option.
Only thing to note here is if you have a G4212A Diode Array detector with a 60mm max-light cartridge flow cell, the concentration of the acetone tracer solution will need to be 0.04% v/v. 0.4% will saturate the detector you will not be able to tell if the gradient is stepping as per normal.
Ibn Sina
Re: Channel A and B
Posted: Tue Aug 12, 2014 3:02 pm
Yes, before the pumps. Rare to have effect on the pumps from which solvent path is selected, unless there's a clogged inlet frit in the reservoir.
