Please: [[ question related to the use of LC-MS ]]
Posted: Wed Jul 30, 2014 4:38 pm
HI, dear scientists please help me
I have been using LC-UV for many years. Unfortunately i have no experience in MS detector ( i.e., LC-MS . LC-MS/MS ETC) and now I have to work on them and need help through the following question:
1- I am familiar with LC-UV i.e, i see the separated peaks then i take the peak area and i do validation accordigly. Is the same thing happen in LC-MS because i don't need to do identification , i just want the peak area, in other way will LC-MS allow me to see seperated peaks and then will I be able to just take the peak area? is the validation such as LOD,LOQ etc same as LC-UV.
2- Interpretation is worrying me is it difficult, where can i start?
3- The problem is i developed a method in LC-UV, do you thing i can transfer it easily
