What is the "SAT" in UV-Vis Specs
Posted: Sat Jul 26, 2014 3:36 am
by thohry
Hi all,
I am not sure if this thead is OK here.
In the data sheet of our UV-Vis, there is a sentence : " Photometric Stability at 340nm, 10s SAT, after 1hr warm-up : < 0.001 A/hr"
Anyone knows what the SAT is in this case ?
Thanks for any input
Regards
TH
Re: What is the "SAT" in UV-Vis Specs
Posted: Sat Jul 26, 2014 4:57 am
by M Farooq
Hi all,
Nothing fancy but
signal averaging time, higher the number, lesser the noise in the spectrum.
Regards.
Posted: Sat Jul 26, 2014 3:33 pm
by thohry
Hi all,
Nothing fancy but
Regards.
Thank you very much. I also thought of something like integration time, but could not figure it out.
Thanks again and regards
