peak shape optimisation for a very hydrophobic compound
Posted: Sat Jul 19, 2014 12:41 pm
Firstly I just want to say that our e2695-2998 is back to normal after the Waters PM. The leaking injector was fixed by replacing seal pack and the needle by the service engineer... I had done the same before but I couldn't fix it-probably because I didn't use proper seal insertion tool to install the seal...
I have been working on optimising the peak shape for a very hydrophobic compound. It is an organometallic material comprising of 6 aromatic rings, 2 long alkyl chains and a heavy metal center. It is heavy and its molecular weight is 1022.21.
I am using sunfire C8 column and the best gradient that I figured out in terms of retention, selectivity and peak shape is 65% ACN, 0.1% TFA, 35%H2O 0.1% TFA.
However, the peak shape is still a bit broad and it has got a bit peak fronting too. The compound is only fully soluble in DMF, DMAc. It can barely dissolve in ACN or MeOH. I am using DMAc as injection solvent and I believed that the sample crushed when it met the mobile phase-this could be the reason for bad peak shape.
I have tried using Xbridge phenyl column to analyse this compound but it didn't help improving the peak shape and reducing the peak fronting. I guessed that phenyl column is only selective towards aromatic compound but can't optimise the peak shape.
Since it is soluble in acetone in low concentration, I am going to try acetone/H2O as mobile phase as well as injection solvent on Monday. If it still doesn't work, will THF help?
Can anyone give me some suggestions on improving the peak shape for this material? I will provide more details if required. I only have 1 week to keep working on this apart from my busy routine analysis.
Thank you!
Thank you!
