Empower Custom field Calculation
Posted: Fri Jul 18, 2014 12:38 pm
Hello all,
Iam new to this forum.
We are using Empower 3 FR1 in our lab.
I have a Question regarding the Empower custom field calculation for Residual solvents Test.
Diluent solvent peak area need to be subtracted from the standard and sample solvent peaks.
The formula I created for this subtraction is = Area-background..(Area)
It’s a peak type custom field. I labelled the diluent as background. So the area from the diluent solvent peak get subtracts from the sample and standard solvent peaks.
But this custom field is not working. Iam getting the same area of sample only. Subtraction is not working.
Could you please help me on this?
