How to dissolve butylbenzene for RPLC
Posted: Thu Sep 01, 2005 3:47 pm
I’m trying to dissolve butylbenzene in 50/50 water/ACN. The problem is that it is immiscible in 50/50 when you add it directly. I tried to dissolve first 0.5 ml in 10 ml ACN, so far no problem. Than I want to add the water (10 ml) but I get phase separation.
I tried heating, but didn’t worked well.
I’m afraid when I use contents like 80% or 90% ACN that the solvent also will act as a mobile phase. The retention time for butyl benzene will not be accurate.
Does someone have suggestions?
