I have a user who is having strange intermittent issues with the Insert Peak tool inside the Lab Solutions Quant Browser.
After selecting the tool, the point wont insert (normally inserts a blue vertical line in place of the black vertical line, and a red one from the point to indicate where it has intersected - this doesn't happen at all - i.e. just displays nothing).
However when I was using it seemed fine, then played up a couple of times, but clicking twice seemed to make it work, so it seems to be very much on and off.
The user also said that a couple of times the monitor had gone completely white (including the system bar at the bottom etc.), for up to 10 seconds, then returned to normal again, which I thought could be another clue to the problem
I thought I would just put this post out there to see if anyone has had issues such as this in the past, or if anyone had any ideas what might be causing it?
Thanks!
