Peak Fronting (Co elution) Troubleshooting
Posted: Thu Jul 03, 2014 7:42 am
Hi all,
I am currently running an HPLC method for the analysis of carbohydrate deficient transferrin (CDT) that has been validated for use on a Acuity UPLC H-Class system.
I have now been running this method for almost a year, but all of a sudden I am now experiencing peak fronting on only a single peak.
I am running blank and test solutions prior to analysis and they go through fine, no issues what so ever, but when I inject the control sample this is when I experience the issue. So I am only seeing this peak fronting on my control samples and only on the one peak, the other peaks in the chromatography are fine.
I have used a competitors control and see the same issue, I have changed buffer LOT numbers, changed the pre filter, preped fresh control, used new HPLC grade water to reconstitute the control and still seeing this issue.
I was wondering if any of you could have any further information on how i can further approach this to try and resolve this issue.
Many Thanks
Many Thanks
