Rsing Baseline in UHPLC
Posted: Tue Jul 01, 2014 10:01 am
Recently I have attempted to transfer an existing HPLC method for a list of 11 analytes to UHPLC, in the hope of reducing the analysis time. I am currently using Thermo ODS Hypersil 250 x 4.6 mm, 5 micron column. The system that I am using is Shimadzu NEXERA X2 LC-30AD, Fluorescence detector.
I have since managed to develop the method, with one major problem, that is the rising baseline after t= 20 mins. I am using acetonitrile and water as mobile phase, gradient method (with 30% acetonitrile from the beginning to 70% acetonitrile in 35 mins, plus 3 more minutes of re-equilibration). Current flowrate is at 1ml/min and pressure is slightly over 100 bars.
So, I would like to know what could possibly be the reason for the rising baseline and how can I try to solve/reduce this?
Thank you.
PS: I have tried to use other columns such as Agilent RRHD 2.1 x 150 mm, 1.8 micron column, but it was no good as there are two particular analytes that tend to co-elute when using a shorter column.
Thank you.
