LogP by HPLC
Posted: Tue Jun 24, 2014 5:53 pm
Hi.
I have setup a basic HPLC method with water and Methanol on a C18 that measure LogP.
To validate the method I have selected reference compounds from the chemistry bible.
The correlation was unbelievable. It also gave very good correlation to already known drugs.
Now suddenly I see that some new compound classes like sulfonamides or give bad correlation to shake or titration.
Now people don't trust the method any more. Someones thinks that if an analysis method is fast than it can't be accurate.
I can see that other people also find good correlation with or without adding octanol. Someone claim that you have to calibrate for each compounds classes. The last thing isn't an option if you are dealing with thousands of compounds. I personal find it a little bit odd that you can have method that only fit the reference compounds.
So what are you experience with Shake Flask, titration Sirius or HPLC?
It also looks that intramolecular hydrogen bonds place a larger role in the HPLC assay. Have you also seen that?
BP
BP
