Amino acid analysis with LCMS
Posted: Wed Jun 18, 2014 8:12 pm
Hi!
We are trying to establish a method for amino acid analysis of feed ingredients and plasma using an LC-MS in our lab but so far no luck. For some of the amino acids such as arginine, histidine, threonine and cystine, the SD is more than 15% using reference amino acids. I was hoping someone may already have figured out how to get robust data.
The instrumentation we have are Agilent 1100 LC and Bruker amaZon SL iontrap MS. We are using dansyl chloride for precolumn derivatization with carbonate buffer to control the pH. After derivatization, the reaction mixture is made up to volume with methanol and 0.1% formic acid. The mobile phases are: 1:1 MeOH:ACN with 0.1% formic acid (A) and 0.1% formic acid (B). We use C18 column and operate the MS on positive scanning mode in the 303-444 m/z. It seems that we may have some solubility issues. I would appreciate any inputs to solve the problem. Thank you.
Best regards,
BPatro
Best regards,
BPatro
