pH Gradient Mobile phases on a UPLC column
Posted: Sat Jun 14, 2014 11:14 am
I am getting peak splitting in all peaks in a following Mobile phase on a UPLC column.: 2.1 x 100mm, 1.7µm
M.P A.: 0.1%OPA pH to 3.0 adjusted with TEA &
M.P B.: (1ml OPA in a200ml Water then added 800ml ACN )pH is around 2.2).
Is it due to different pH mobie phases??
