Retention times increasing
Posted: Mon Aug 29, 2005 1:12 pm
Dear members of this forum,
I need your help owing to I have problems with the variability of the retention times, it increase with the time. The mobile phase is not volatile and the flow is stable during all the analysis (1 ml/min). Some weeks ago I have problems with the pump and the technician change any seals but the sapphire piston is not in good conditions but it was not changed. I suspect the problem is the pump which it is not working properly but I do not know any test to evaluate its performance. I conditioned the column for about 40 minutes (about 30 column volumes) and I discard this problem.
I will apreciate any opinion in order to solve my problem,
Diego Delmonte
Diego Delmonte
