tertiary amines by GC-MS
Posted: Thu Jun 05, 2014 3:41 pm
Hi all
I have a group of closely eluting peaks from African wild dog preputial gland that elute slightly before benzoic acid on a Restek wax column, and whose mass spectra consist almost solely of an m/z 58 ion, with a few very small peaks for lighter ions. These search on the NIST library as various N,N-dimethyl..........amines, sometimes with other substituents. The 58 fragment is presumably (CH3)2NCH2 but the spectra are completely uninformative as to what the "tails" might be.
Does anyone have any suggestions as to how I might get at least a hint of the structures ? - GC-MS based techniques would be preferred since that is all I have on site. I had thought to reduce ionisation energy to try to get some molecular ion, or otherwise to increase it to try to fragment the "tail". CI is also a possibility. Failing an analytical approach, are there any educated guesses as to likely molecular weights given elution from a 30 m x 0.32 mm x 0.5 um PEG column running helium at 35 cm/s about 1 min before benzoic acid at around 180C ?
Thanks.
Thanks.
