Question about SPME, solubility, and volatility.
Posted: Wed Jun 04, 2014 7:24 pm
by Lawborne
I'm working with SPME to determine how well a certain steroid (androstenone) volatilizes in the air. When I have it in isopropyl alcohol I get a peak in GC-MS but when I have the same concentration in any type of oil (I've tried canola and Crisco) I do not see any peak. If I had to guess it is because androstenone is very soluble in oil compared to isopropyl alcohol so it is less likely to become volatile. Thanks in advance.
Re: Question about SPME, solubility, and volatility.
Posted: Wed Jun 04, 2014 8:09 pm
by Peter Apps
That about sums it up.
Androstenone is a much larger molecules than is usual for SPME sampling and I would be interested to hear how well it performs since I am also working on airborne chemical signals:
http://www.bpctrust.org/bioboundary-project.asp
Welcome to the forum.
Posted: Thu Jun 05, 2014 2:50 pm
by Steve Reimer
The octanol - air partition factor is not favorable for large and not very polar compounds in oils. I see less than 10% of the response when comparing naphthalene from water and naphthalene from waste oil when I do headspace (vacuum distillation in my case).
I see that Henry's law constants along with Kow and Koa data is available on Chemspider. It could give you a good starting point.
