help about convert AB .wiff data to mzXML format using TPP
Posted: Sun Jun 01, 2014 3:24 pm
hi all:
I am trying to convert AB.wiff raw data to mzXML format, using Trans-Proteomic Pipeline (TPP) , but it doesn't work, the message showed that •Command is not running,Did NOT kill command. file not found: not created or deleted; what may be the problem ? any help will be appreciated! thanks!
