SPME on Gerstel CIS septumless injector
Posted: Wed May 21, 2014 7:52 am
by BMU_VMW
We are trying to set up an SPME methode on a Gerstel MPS2 autosampler 'injecting' on a Gerstel CIS septumless injector.
Fiber is a 24Ga that should be suited for this type of injector (http://www.sigmaaldrich.com/catalog/pro ... &region=BE).
Problem is that when the fiber is in the injector the injector is leaking A LOT. The injector has been serviced, all seals have been replaced and yet the problem persists. Obviously I can't find any components in my chromatogram.
Does anyone know what to do?
Is it at all a good idea to use a septumless injector for this purpose or should I prefer a regular injector?
kind regards
BMU
Re: SPME on Gerstel CIS septumless injector
Posted: Wed May 21, 2014 10:04 am
by Peter Apps
Are you sure that the sharp edge of the square-cut SPME needle is not scratching the polymer seal at the top of the injector ? It is possible to round off the edge by careful use of fine abrasives, but it is probably easier just to use an injector with a septum. Is there a particualr reason that you need to use a septumless injector ?
Posted: Wed May 21, 2014 10:36 am
by CE Instruments
Merlin microseal ? Note there are different sizes of seal and you need the large one to avoid damaging it when you use an SPME needle.
Posted: Wed May 21, 2014 11:51 am
by BMU_VMW
@ peter:
we use this injector because the autosampler is suited for SPME and it is a GC-MS/MS.
The other device we have with an MPS2 autosampler and regular injector is a single quad MS
@CE Instr.
we use a gerstel septumless sampling head on an CIS PTV
http://www.gerstelus.com/products.php?prod_id=22
The outer diameter of the needle is the same as the one we use with regular liq injections, so it should seal. Major differences are the time in the injector: seconds for liq and minutes for SPME, and the injector temp.: +/-40°C for liq and 200°C for SPME.
Posted: Wed May 21, 2014 11:59 am
by Peter Apps
@ peter:
@CE Instr.
So there is no analytical reason (i.e. contamination, baseline drift etc) to use the septumless injector.
I would be very surprised if the outer diameters of the needles were the same within the tolerances needed to give a gas tight seal. It is years since I used a CIS - is there a compression adjustment for the cylindrical needle seal ? If so you could try to tighten it, but then you run more risk of scoring the seal with the edge of the needle tip.
You could try threading a septum onto the needle, then adjusting the autosampler VERY carefully to compress the septum against the top of the injector so that it seals above the CIS needle seal.
Posted: Wed May 21, 2014 12:43 pm
by BMU_VMW
No not really, it has been bought this way to prevent septum bleed. the instrument is used for liq injection, but I'm trying to make a SPME methode for odor compounds and this instrument has al the features I need (triple quad, MPS2, Rxi5silMS column), except an injector with a septum.
The injector 'seals' with a teflon ferrule that is possitioned under a nut that can be tightend. I've already done that to the max. If too tight I risk bending the needle.
I don't think this is possible since there is a needle-guide on the autosampler. The needle is not protruding so there is no space to put a septum. It is the needle-guide that is touching the top of the injector.
BMU
