Peak Area Declining Over Time
Posted: Sat May 17, 2014 8:37 pm
I have been using an automatic switching valve to inject 1 mL of gaseous sample from a sample loop into a Shimadzu 2014-GC. I have run at the same conditions for several months and routinely conduct "bypass" checks to ensure my feed composition is not changing. Over the past 5 months I have seen the peak area and height of my feed chemical dropping gradually. To iterate my point, the peak heights of the compound over the past few months, for the exact same injection technique, are below:
Jan - Area = 13.1e6 Height = 2.9e6
Feb - Area = 7.1e6 Height = 2.1e6
March - Area = 6.0e6 Height = 1.8e6
April - Area = 6.3e6 Height = 1.3e6
May - Area = 4.6e6 Height = 1.0e6
I typically keep the GC oven and detectors hot all the time. So far in troubleshooting I have replaced the inlet liner and injection septum, cleaned the auxiliary sample loop, and checked all tubing for leaks. My only remaining suspicion for the declining peak over time is the loss of sensitivity of the FID detector.
Any ideas on what the problem could be?
