floating electric signal
Posted: Thu May 15, 2014 7:31 pm
by jgort
I work on a 450 Varian which has constantly had a floating electronic signal since I started 2 years ago. We are often unable to get a blank could it be the floating signal and/or has anyone else dealt with this issue? The 450 runs dual collumns of Chromosorb PAW60-80, 30 feet X 1/8 inch SS inlet Steel. Loop size is .5cc.
Thank you for your assistance,
J. Gort
Re: floating electric signal
Posted: Sun May 18, 2014 11:07 am
by carlo.annaratone
May it be an unshielded/non properly grounded appliance on the same power line?
Posted: Mon May 19, 2014 1:19 pm
by jgort
Thank you for the information. I will check into that.
Posted: Tue May 20, 2014 4:43 am
by cat4lyst
fid? specifying the detector type would be helpful
