hp 1090 series II
Posted: Tue May 13, 2014 8:48 pm
by rayanemiranda
I am trying to revive a hp 1090 series II which was last used in 1998. I want to operate in local mode; however, the message "key inhibited in remote mode" is displayed each time I do press anything. How should I proceed?
Thank you.
Re: hp 1090 series II
Posted: Tue May 13, 2014 8:56 pm
by rayanemiranda
I already tried the the procedure described in the manual, which says to press press "escape" when the message " method data ok" appears.
Posted: Fri Aug 15, 2014 10:34 pm
by chembionuke
Sadly I do not have an answer, only the same problem. Have you come across a solution offline?
Posted: Sun Aug 17, 2014 12:09 am
by tom jupille
Have you tried contacting Agilent tech support?
