Wrong mobile phase used for a column!!
Posted: Mon May 12, 2014 2:52 pm
Dear all,
while cleaning my column and the system pre-analysis, I have chosen a created method for another analyte and the wrong mobile phase passed through my column for cca 10-15 sec (flow= 0.2 mL/min).
I stopped the flow as soon as I saw what I did, put the right mobile phases and proceeded with the cleaning and conditioning process ( after the cleaning, I leave the system to stabilize for 10 minutes with the method Im going to be using). When that was over, the column pressure was slightly higher than in the last analysis of the same analyte (instead of 181, it was 189 bar).
Is it possible that I have ruined the column it if the pressure is just slightly higher?
