Empower Replace function
Posted: Sun May 11, 2014 6:09 am
by ama1001
I am trying to replace a null value for Amount with Not Detected. I did it in 2 steps:
REPLACE(amount,-9999)
ENUM( ........., EQ(amount,-9999)
In the translation table, "Not Detected" is the value of the enumerated custom field. However, when the peak is missing, amount does not get the value -9999 and the enumerated custom field does not equal, "Not Detected". I thought replace will assign a new value when the field equals Null.
What am I doing wrong?
AA
Re: Empower Replace function
Posted: Mon May 12, 2014 5:49 pm
by shaun78
There is a built in database code for "Not Detected" in Empower. That code is -60002.
If I had to code this, I would personally use:
EQ(Peak Type,"Missing")*-1*60002
In this field, if a named peak is not found, then the result is 1*-1*60002, or -60002 which the database will automatically translate as Not Detected. Use the appropriate REPLACE function to get that Not Detected into the cell you are after.
Posted: Wed May 14, 2014 1:00 am
by ama1001
Thanks. I will try that.
