We use batch review for post processing in an older version of Chemstation (rev A 10.02) for HPLC. I'm trying to automate some of the processes that our chromatographers do. I'm a programmer, not a chemist or chromatographer. The Chemstation macro programming guide is vague, so I'm asking here.
I'd like to have a macro that cycles through all of the runs in the currently loaded batch table. How would I access that table and obtain a list of the sample names, run indices, and directory names for each run in the currently loaded batch (not the entire sequence that was run, but only the runs currently loaded).
Once i have this info, how do I programmatically cycle through each of these runs, loading them into chromreg so I can access the data for each run?
What I'm ultimately trying to do is to export 3 signals from each run into temp files, then excecute a python script I wrote (execwait I believe), to process the data from those signals and generate figures.
Any help would be appreciated.
Jeff
