Chloroform GC-FID contaminating peaks?
Posted: Fri May 02, 2014 3:18 pm
by Jaff
Hello all,
I was wondering if anybody has come across this anomaly when extracting lipids using the standard Folch protocol. Having removed the chloroform phase, I evaporated it to dryness at 37oC in a vacuum evaporator and derivatised the resulting pellet to FAMEs for GC-FID analysis. Amongst the expected FA peaks, I got these 3 contaminating peaks at 1.789, 2.896 and 3.027.
I repeated the process without the sample, so just chloroform:methanol, removed chloroform phase, evaporated to dryness and while no pellet was present, I used the tube to mix the reagents for FAME derivatisation. I got the same 3 contaminating peaks at 1.789, 2.896 and 3.027 (see attached - peak at 9.815 is methyl behenate).
I have discounted contamination/issues with the column, GC system, FAME reagents, hexane etc. The peaks were evident for 2 separate chloroform batches and were not present when chloroform was run directly on the GC. The system is an Agilent 7890A with a DB-23 column.
My best guess is that they are contaminating artefacts in the chloroform or from the plastic eppendorfs used during evaporation (I know plastic is generally considered a no-no with chloroform but it was only used during the evaporation stage and the peak at 1.789 is so intense that I find it hard to believe that there would be that much interference, given that detection is with FID and not MS - although maybe I am wrong?!)
Does anybody out there have any thoughts or suggestions or have had similar experiences? I could just ignore the peaks but I would rather know what's going on!!
Thanks in advance
Jaff
http://imgur.com/2vf8FZ3
Re: Chloroform GC-FID contaminating peaks?
Posted: Sat May 03, 2014 4:04 am
by Don_Hilton
I've done some work where plastic pipette tips are used, and I come up with all kinds of lipid related stuff in the chromatogram. Try using all glass and with solvents that have had no contact with plastic and see how it works.
