The AB pump had to be run as a 10 series AD in order for Chromeleon to recognize it. Any tricks that might help make installation easier are appreciated. Also, the pump specs describe it as being able to do 2 or 3 solvents. Is the 3rd solvent line an add or or standard issue with all ATs?
Thanks!
