conversion from pico amps to counts?
Posted: Thu Aug 25, 2005 7:31 pm
I am running a HP ChemStation with a HP 5890 GC. I am trying to troubleshoot some drifitng baseline issues. First, however, I am concerned with how the signal windows in the Method & Run Control mode vs the Data Analysis mode are related. The readout on the GC and online plot signal window in the Method & Run COntrol mode is time vs pico amps. The plot in the data analysis window displays time vs counts. Is there a way to figure out the conversion between pico amps and counts? If it is adjustable, where is it done on the software? Thanks much.
