Reverse Phase Column Cleaning
Posted: Fri Apr 25, 2014 1:03 pm
I have a Agilent PrepHT 300SB-C18, 21.2x250 mm, 7 um reverse phase column that my PI brought with him. It's severely fouled, but it's significantly larger than any other column available to me. Employment of such would reduce the time of my purification significantly.
I don't know if it was stored properly. I know it was used in the past for synthetic peptide and oligonucleotide purification. The column information says it can be reversed to remove pluggage. I think I've read up on a decent amount with most of what I know coming from a 2003 Column Watch article by an Agilent Employee, Ronald Majors. It has some suggestions on solvents order cleaning but I'd prefer to run it by the collective knowledge here to double check and to save time/solvent.
There are general ordering of organic solvents with IPA at the beginning and end and there are also ones that just call for long flushes of 1% TFA, AcOH, or some propanol mixture there of. It also recommends that you reduce the flow rate for some. The column can handle 21 mL/min? and our system can put out 10 mL/min. So any advice about any of this would be great.
EDIT: This is the ordering the aformention article suggests for protein contamination.
Solvent Composition ( 20 column volumes each )
Acetic acid 1% in water
Trifluoroacetic acid 1% in water
0.1% Trifluoroacetic acid–propanol 40:60 (v/v) (viscous; use reduced flow-rate)
TEA–propanol 40:60 (v/v) (adjust 0.25 N phosphoric acid to
pH 2.5 with triethylamine before mixing)
Aqueous urea or guanidine 5–8 M (adjusted to pH 6–8)
Aqueous sodium chloride, sodium 0.5–1.0 M (sodium phosphate pH 7.0)
phosphate or sodium sulphate
DMSO–water or dimethylformamide–water 50:50 (v/v)
Followed with 40-50 column volumes of HPLC grade water.
