Hitachi fittings?
Posted: Mon Apr 21, 2014 5:59 pm
I have inherited a Hitachi L-6200 pump that we need to use for a project. All we need is the pump for a non-chromatographic application.
It's running, but we don't have any fittings and I need to get the 1/16" line attached to the exit from the drain valve. Of course, this is the high pressure side.
I've struggling with finding the fittings (nut and ferrule). ASAP Analytical is looking. Most of the supply houses list other manufacturer's parts, but not Hitachi. Is the Hitachi fitting a standard size? Would something like a Rheodyne fitting work?
