Keypad disabled on 6890 with Chemstation on Win7
Posted: Sat Apr 19, 2014 5:47 pm
I have a couple of computers running Win7 with B Version Chemstation. One with a 7890 and 6890 and another with a 6890 and a 6850. Both computers drive a valve based injection instrument. The problem is, the 6890 will not start from the keypad on a manual start. The display on the 6890 reads Keypad disabled and you have to start the run at the computer (under Run Control) then push the start button on the instrument. On the 7890 you can simply start the instrument by pushing the start button (which was true of the 6890 before moving to Win7 PC.) The same problem exists on the other computer running the 6890 and 6850. Is this a function of the B Version software? Is there a way around this?
Best regards,
AICMM
Best regards,
AICMM
