Ion Pairing Reagents - TBA Phosphate
Posted: Wed Aug 24, 2005 12:04 am
I have a compound that forms an enolate and therefore require the use of Ion-Pairing HPLC. Most literatures suggested the use of tetrabutylammonium phosphate in methanol and PIC Reagent A (manufactured by Waters) in water.
However, both TBA phosphate and PIC Reagent A are expensive to get.
I'm wondering if anyone out could help me out with a few ion-pairing basics?
1) What is the reason behind using TBA? My supervisor suggested the use of ordinary cationic salts (eg ammonium) to produce the charge. I personally don't think it's going to work, there must be a reason behind why people are sticking to the use of TBA and not cheaper chemicals. Does anyone know why?
2) What is the main difference between TBA phosphate and TBA sulphate? The latter is cheaper for some reason.
3) Does anyone know what is contained in the PIC Reagent A? As far as I know, it is basically TBA phosphate buffered at pH7.5. Is is possible to make our own rather than paying over $100 for 25 ml?
Would appreciate with any contribution!
Thanks in advance.
Judy
Thanks in advance.
Judy
