Column Activity Pump DMDCS through Column?
Posted: Tue Apr 08, 2014 12:39 pm
I have a few Gc columns that have devloped activty that solvent rinsing nor clipping has not cured. I was wondering if treating it like a cleaned liner by pumping Dimethyldichlorosilane through using the solvent pump would deactivate the column and restore it?
Obviously it won't work on a wax column but DB-1's and 5's?
