Methanol Tailing with RTX-502.2
Posted: Mon Apr 07, 2014 7:57 pm
I'm running a method for methanol determination in water using an RTX-502.2 column phase. My column dimensions are 105m x 0.53mmID x 3um. My carrier gas is helium and my solvent is water. I use 1-butanol as an internal standard. The remainder of my method parameters are as follows:
Injection size: 0.5 ul
Injector temp: 200 C
Detector temp: 200 C
Oven Time Program:
Initial Temp 1: 50 C
Initial Hold 1: 3 min
Rate 1: 10 C/min
Final Temp 1: 140
Final Hold 1: 0.1 min
Rate 2: 25 C/min
Final Temp: 250 C
Final Hold: 10 min.
Total Run Time: 26.5 min.
For almost every injection, the 1-butanol internal standard peak is perfectly symmetrical, while the methanol peak exhibits extreme tailing (including certain "humps" at the tail end of the peak that resemble interference). Are there any parameter tweaks that you would recommend? I was thinking that perhaps I would raise the initial temperature from 50 C to 60 or 70 C. Perhaps that would help in eliminating the tailing? What do you guys think?
Curtis
Oven Time Program:
Rate 1: 10 C/min
Final Temp 1: 140
Rate 2: 25 C/min
Final Temp: 250 C
Final Hold: 10 min.
Curtis
