HPLC Method for Quantification of Urea
Posted: Wed Apr 02, 2014 5:16 pm
Hi all,
I wanted to know if any has used a specific method for quantifying urea.
Currently I am doing:
Dissolving pure urea in 90:10 Acetonitrile:Buffer (ammonium acetate, acetic acid, pH 5)
Method:
Mobile phase- 93% acetonitrile 7% buffer
Column- NH2
UV- 200, 210, 230
RI Detector
Inj Volume- 5 uL
Flow- 1 mL/min
Column Temp- 40
So far I have not even been seeing the urea. I have made up many concentrations and nothing seems to have an effect. There is a peak near 5 on the RID and DAD, but it never changes with different concentrations. The detector is not saturated and neither is the solution.
Any ideas or experience would be greatly appreciated.
Thanks!
Method:
Column- NH2
UV- 200, 210, 230
RI Detector
Inj Volume- 5 uL
Flow- 1 mL/min
Column Temp- 40
Thanks!
