Empower2 Processing Error
Posted: Wed Apr 02, 2014 3:15 pm
by ChromoQueen
Has anyone ever encountered an error where Empower processes the results individually when Batch Processing had been specifically selected?
Re: Empower2 Processing Error
Posted: Wed Apr 02, 2014 5:18 pm
by DR
Batch processing is supposed to generate individual result files in addition to a result set file.
Posted: Wed Apr 02, 2014 5:34 pm
by ChromoQueen
The real issue is that a result set was never created even though batch processing was performed.
Posted: Thu Apr 03, 2014 2:48 am
by DR
Check the projects table space quota and the message center...
Posted: Fri Apr 04, 2014 3:30 pm
by ChromoQueen
This happened right after more space was added to the table. Is that what caused this?
Posted: Fri Apr 04, 2014 6:07 pm
by DR
Usually, it won't batch at all if you're short on table space.
Since you added table space, batch it again. If you get a results set this time, it was most likely lack of table space causing the problem.
Posted: Tue Apr 08, 2014 1:38 pm
by aceto_81
As usual: what's in the message center?
Posted: Tue Apr 08, 2014 6:38 pm
by Hollow
after adding more table space, did you close and restart the project before processing?
do you process the sample set or just seleceted injections? In the latter case, no result set will be produced, just single results
